idles really low, then to high
Old May 31, 2011 | 09:44 PM
ripnet_45's Avatar
ripnet_45 is on a distinguished road
Default idles really low, then to high
i have an 89' 4.3L, and i recently did a complete tune up to it, and it still is having idle problems. When it is in park it will idle really low when i first start it and it dies sometime if i don't give it a little gas, then if it gets to where it will idle w/out my help on the throttle, it will get to where it almost dies then on its own it idles really high around 2500 rpms for a little bit before going back down to way to low. and it just repeats this up and down cycle?
any advice would help.
Old May 31, 2011 | 09:57 PM
teagueAMX's Avatar
teagueAMX is on a distinguished road
Several things come to mind but here's a few:
Could be a vacuum leak, and the idle control motor/computer is trying to compensate.
Could be the idle control motor
Could be low fuel pressure - either regulator or fuel pump
Could be fuel filter
Old May 31, 2011 | 11:13 PM
ohsofly's Avatar
Might want to check function of the EGR valve too.
Old Jun 1, 2011 | 12:02 AM
wyomingresident's Avatar
wyomingresident is on a distinguished road
I think vacuum leak.
Surging engines can be EU searching for right idle absent of proper vacuum.
Old Jun 1, 2011 | 02:37 AM
ripnet_45's Avatar
Alright ill try all those and see which one works. thanks
Old Jun 4, 2011 | 04:00 PM
wazzledoozle's Avatar
wazzledoozle is on a distinguished road
If you pull the EGR off, you can replace the gasket with a screened one that could prevent future jamming of the valve.
LukasP
Jan 16, 2015 03:24 PM
sparkie624
Aug 12, 2011 11:31 AM
tinkstar1308
Feb 25, 2011 03:43 PM
ryanmancl
Jul 2, 2010 04:44 PM
muleman
Mar 18, 2009 07:29 PM
