ingintion lock
Old Aug 6, 2012 | 01:27 AM
tuffypwn's Avatar
tuffypwn is on a distinguished road
Default ingintion lock
Is there an easy way to remove the ingnition lock on a 91 blazer s10
Old Aug 6, 2012 | 02:01 AM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
Slide hammer?
Kidding.
You will have to pull the wheel, the lock plate and the turn signal switch to get to the screw that holds it in.
Old Aug 6, 2012 | 09:29 AM
tuffypwn's Avatar
Is there a way to remove it without the key lost the key and need to get it to turn to move
Old Aug 6, 2012 | 03:34 PM
Sure is. You don't need the key to remove it.
Old Aug 6, 2012 | 06:19 PM
tuffypwn's Avatar
Ok how ???
Old Aug 10, 2012 | 09:33 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
you need a steering wheel puller. rent one from autozone. pull the wheel. take the plastic piece off the top. it just snaps off. then make yourself a lockplate compressor with some steel and use the nut to compress. or get another person to push down with thumbs as you remove the lock washer thing lol. take the turnsignal switch out then theres a screw that holds the key switch in place. then pull it out
Old Aug 13, 2012 | 08:36 AM
tuffypwn's Avatar
How do you remove the lock without the key without damaging the column
95blazerlt
Jan 5, 2010 09:08 PM
blazerrick
14
Dec 28, 2005 09:07 PM
BLAZER98
Nov 28, 2005 11:48 AM
juliensales
Mar 29, 2005 12:16 PM
May 27, 2004 12:15 AM
