Interior Lights Hung Up
Old Jun 23, 2008 | 08:48 PM
Big E's Avatar
Big E is an unknown quantity at this point
Default Interior Lights Hung Up
My Interior lights on my 94 S10 Blazer are hung up. They won't go off. Had to pull fuse out to get them to go off. They ran my battery down. Any clue why they would be doing this? I checked the door jams and even with the button pushed in they still would not go off. Please help.
Old Jun 23, 2008 | 08:58 PM
TripleBlackBlazer's Avatar
Default RE: Interior Lights Hung Up
Do not take this the wrong way, but is your dimmer switch all the way up?
Old Jun 24, 2008 | 01:14 AM
Chevy Lover's Avatar
When you push the door jam switch is there a flicker at all?
I would remove the door jam switches and see if they go out, it could be a switch shorted to ground.
Old Jun 24, 2008 | 03:44 AM
neo71665's Avatar
Make sure the switch on the dash is off and the switch in the cargo area light is off first. Then check your door switches.
Old Jun 24, 2008 | 06:33 AM
Yeah, once you have ruled out the obvious, you need to remove ALL of the door switches and check them. They should show continuity when the button is out (from the spade in back to the body of the switch) and open when the button is in. If any test otherwise, there is your problem.
Old Jun 24, 2008 | 08:23 AM
Big E's Avatar
Yeah I checked the dimmer switch and cargo switch they are both off and are not bothering it. I will check the door jam switches and see if that is the problem thanks!
Old Jun 24, 2008 | 05:44 PM
neo71665's Avatar
About a year ago the cargo area switch started going out on mine and it would turn the lights on when I hit a bump or the dog bumped the truck. Saw the dog hit it one night and the light popped on and I thought the dog was gonna run on top of the pond trying to get away, lol.
Old Jun 24, 2008 | 05:48 PM
Big E's Avatar
Hey guys thanks for the advice I figured it out!
Old Jun 25, 2008 | 11:58 AM
neo71665's Avatar
Well I guess I'll ask the stupid question, what was it?
twisted125
Jun 21, 2011 01:53 PM
greendouglash
Feb 3, 2011 05:13 AM
edavison
Dec 20, 2010 09:55 PM
cdp1250
Feb 6, 2010 01:11 PM
cjs030901
Jun 7, 2007 08:51 AM
