interior lights not working
Old Feb 28, 2010 | 01:47 PM
papabears93's Avatar
papabears93 is on a distinguished road
Ok, just tried jumping both wires and nothing. So i gounded the white wire and nothing as well. I tested for 12 volts at the firewall in the harness that runs under the the drivers seat to the center door pillar and had power at the fire wall side but not at the center door pillar side? Is there a break maybe under the seat that I cant see? I know that abig84 said that is where his was so maybe the ground is cut there?
Old Feb 28, 2010 | 03:41 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Man anything is possible. If you have power that suddenly stops then you probably do have a cut wire. Looking at the wire routing diagram in the book you have all the wiring running under the driver seat and runs down that side of the truck after splitting off to go to the rear door jambs. I would indeed start there and work forward. There is a big splice there too. I would pull the seat and peel back the carpet and follow it out. You might check all the wiring because your tail lights and rear dome light is in the mix there too.
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
baseball061307
Feb 28, 2013 09:55 AM
tululilopo
Oct 13, 2010 04:35 AM
6gear
24
Mar 18, 2010 11:32 PM
chrisblaze
Dec 6, 2009 12:27 AM
