Jeep heater question
Old Dec 8, 2006 | 01:35 AM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Jeep heater question
My mom called and said her heat in her '00 Cheerokee Sport isn't blowing out "hot" air, just warm air. I don't know that much about heating and air conditioning so I thought I'de ask. And also, when I turn the blazers heater on there is a loud tinking noise where my heater is and it sounds like the fan hitting somthing. I don't want my heat to go out... Is this a problem?
Old Dec 8, 2006 | 02:26 AM
Chevy Lover's Avatar
Default RE: Jeep heater question
On the Jeep, check that the radiator is full, next check the heater hoses to see if they are both the same temp. If the heater hoses are different temperatures then the heater core is plugged
Does your heater fan have that noise at all blower speeds?
Old Dec 8, 2006 | 02:33 AM
4lowlife's Avatar
t stat?
Old Dec 8, 2006 | 08:18 PM
The hoses are the same temp. Yeah it makes the noise at all speeds. And on the jeep the T stat was replaced not too long ago. Didn't help.
Old Dec 8, 2006 | 10:49 PM
4lowlife's Avatar
maybe the core went. or the fan motor. Good luck!
Old Dec 8, 2006 | 10:55 PM
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Sounds like the heater core is going or it is plugged up. I have heard many stories about them getting plugged up. Can you tell us anything that she did prior to this happening?
Old Dec 9, 2006 | 02:04 AM
All I know is the T stat was replaced not too long ago. How would I go about unplugging the heater core? I'm acually not sure where it is excatly...
99 Cherokee - zmotors.biz-google
Sorry for long link. This isn't hers but its close enough. Click picture number 3-5 and kinda let me know where it is and what I should do. Thanks.
*EDIT by swartlkk* - fixed long link
Old Dec 9, 2006 | 03:46 AM
If the coolant level in the rad is full and the temperature of both heater hoses is the same you should probably change the thermostat.
Then re-fill the rad and run the engine til the thermostat open and top up the coolant.
There are probably 2 bolts holding the thermostat housing.
[IMG]local://upfiles/2910/F05C5A6B4E754726A988A9EEB4388317.jpg[/IMG]
Old Dec 9, 2006 | 03:44 PM
hmmm... How would I go about seeing if its plugged up or not? Cause I wanna check that first. Cause my dumb *** grabbed the wrong hoses
Old Dec 9, 2006 | 04:30 PM
tycobb280's Avatar
tycobb280 is an unknown quantity at this point
check the temp guage. if its at normal temp then its not the t-stat. its probably clogged heater core. it happened to my blazer when i first got it. there will be 2 hoses that go through the fire wall. they should be 3/4" to 1" in diameter. take both of them loose from the fire wall and run water through the heater core, opposite direction of normal flow. i ended up getting my whole system flushed because i flushed the heater core about 4 times and it just kept getting clogged.
