Junkyard ECM? Anyone done this?
Old Oct 19, 2013 | 09:49 AM
cas's Avatar
cas
cas is on a distinguished road
Default Junkyard ECM? Anyone done this?
(skip down)
Since I've about run out of things to change trying to fix my problem, I'm looking at swapping the ECM. New ones are of course expensive and "require local programing" or whatever the heck it says.
Looking on Ebay I see salvage one running between $40-$60. My question is has anyone gone this route?
Is it a "plug and play" type thing, or will I still need to get it setup by someone (whom I wouldn't know)?
Like many things, they show compatibility charts for this year/model through those years/models. Will any of those work, or do I need one that came from/programed for a "94 S10 W vin, 2dr, 4WD"?
Anyone got some input?
Edit to add: Okay, after some more research I found my answer. If I go this route, can anyone recommend a place to send it?
Old Oct 26, 2013 | 01:13 PM
cas's Avatar
cas
Oooookay, now I'm really scratching my head. The computer in my truck looks nothing like what I'm seeing it's supposed to. Everything I see online shows it as a large metal box with two plugs. My truck has a small/medium sized metal box, with a smaller box piggybacked onto that. Two plugs on the larger, one on the smaller.
Anyone know more about this than the almost nothing I do?
Old Oct 26, 2013 | 02:04 PM
abig84's Avatar
i know on the older trucks you were able to swap out computers. my 1990 c1500 with a 305 has a computer out of a 89 k30 with a 350 and works fine. but try to find the closest to your year as you can
Old Oct 26, 2013 | 03:58 PM
cas's Avatar
cas
Searching more online I see examples that look closer to what I have and the other small box makes sense now at least. Maybe it's an optical illusion but the main ecu looks about 3/4 the size I was expecting, 3/4 the size of what I have to replace it with. The mountings aren't even close.
I can't figure out how to get the damn thing down!!1
Old Oct 26, 2013 | 05:22 PM
cas's Avatar
cas
Well I figured it out and it was an optical illusion. It's the same size as what I have on hand.
If I'll ever get it back up in there on the other hand…. lol
Old Feb 4, 2014 | 04:08 PM
Bernard's Avatar
Bernard is on a distinguished road
Hello Cas.Hope all is Going well with your Blazer.You know its Better go new than used.you just dont know if thers any problems to come.
Old Mar 16, 2014 | 05:22 PM
cas's Avatar
cas
Touching base back on this one… that wasn't it, so I'm glad I didn't spring for a new one.
So I have both a used working ECM and EPROM if anyone's looking to buy.
Does this forum have a classifieds, I've never bothered to look? I've got a whole box of parts that I won't need at some point (when this thing finally gives up the ghost, or I just get tired of fixing it. Which I came close on today.)
Old Apr 1, 2014 | 07:11 PM
NCSurvival's Avatar
NCSurvival is on a distinguished road
May want to hold on to it, JUST IN CASE.
Old Apr 2, 2014 | 08:40 AM
cas's Avatar
cas
Mmm.... Since the truck is probably a 3 x 3 foot cube right now, I probably won't need it.
roddy
Jun 28, 2012 04:52 PM
PetSue
Oct 17, 2010 02:02 AM
S10Blazer
Dec 6, 2009 01:58 PM
Confuused69
Nov 17, 2009 01:28 PM
Tippman7641
Jun 1, 2008 06:41 PM
