Lift Question
Old Aug 10, 2007 | 05:01 PM
t_money_nwa100's Avatar
t_money_nwa100 is an unknown quantity at this point
Default Lift Question
I have a 91 S10 Blazer 4x4 i know how to do the suspension lift on the back but not sure what to do or use on the front..it has indipendent suspension so im lost.
Old Aug 10, 2007 | 06:11 PM
RCars2's Avatar
RCars2 is an unknown quantity at this point
Default RE: Lift Question
Well for the front of your truck it has independant suspension supported by torsion bars. The torsion bars are those really long bars the run from the front a-arms back to a crossmember. These act as a torsion spring (thus their name) so they twist instead of compress like normal springs. What you can do with these is locate the crossmember they attach to and you will find they are connected to a "key" that looks tier drop shaped (ill link to a pic in a sec). This has an adjustment bolt. If you tighten this bolt 5-6 full turns you will get about 1.5-2 inches of lift in the front. Very easy to do.
Here is the bad news. This can put strain on your front end causing premature wear of cv joints and ball joints. So long as you are ok with this and you keep everything greased up you will be ok. Just be prepared when stuff breaks.
Torsion bar key looks like this
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
texastrails
Suspension Tech
Jun 21, 2007 12:36 PM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
