May have found rough idle cause (with pics)
Did a warm compression test with WOT, no difference. Got desperate and did my own 'induction cleaning'. I sprayed and emptied two bottles of Deep Creep in the intake at about half throttle...amazingly enough the idle has smoothed out and the throttle response has almost doubled. Hope it lasts! Seafoam does it again. Maybe it unstuck my valve
Finally did a cylinder leak down test for #5 today. Put it at TDC (distributor pin pointing at #5 and with it puffing out air) and put compressed air in it. Air came out of the intake pretty loud. I moved it and 1/8th of a turn all the way through #5's compression stroke, and the leakage got quieter, but never went away and still hissed pretty good
Intake valve = stuck or bent.
So, what can I check without taking the head off? I've got the valve cover off, and the valve spring doesn't look broken. Is there anything else I can check?
Thanks.
Intake valve = stuck or bent.So, what can I check without taking the head off? I've got the valve cover off, and the valve spring doesn't look broken. Is there anything else I can check?
Thanks.
Finally took her in to a guy I trust. #5 cylinder dead. What I thought was lifters was bottom end noise
Left side head valves were bad noisy. It was gonna cost more than a new engine to fix everything, so I'm getting a shiny new Jasper. At least I'll know how this ones been treated. Thanks for all the help.
Bonzaibob
Apr 17, 2012 11:11 AM
Dan 128
Jun 10, 2011 11:58 PM
TimmyBlaze
Dec 23, 2010 11:01 PM
