Need help with a 92 S10 Blazer 4.3L
Old Mar 23, 2011 | 04:20 PM
brian.baker's Avatar
brian.baker is on a distinguished road
Default Need help with a 92 S10 Blazer 4.3L
At first, I had spark coming from the coil, but not to the wires, it was running 1.5 lbs of fuel pressure from the tank and just wouldnt run. I replaced the fuel pump, fuel filter, Ignition control module, throttle position sensor, rotor, cap, wires and plugs and air filter. After that, the truck ran strong for about two days then started with its BS again. I sprayed a bit of starting fluid down through the injection system and it fired off, then died. So then, i sprayed more and when it fired, i kept spraying and the truck stayed running so im thinking its not getting gas. While the key is in the "start" position, the injectors are spraying fine, but as soon as the key gets back to the on position, they stop spraying. My guess is the computer, ignition switch or need new injectors and have to rebuild the injection system.
Has anyone had the same experience with this or know anyone who has? Really getting my butt kicked by this truck.
Old Mar 23, 2011 | 06:20 PM
ohsofly's Avatar
Which engine are we looking at here? Z or W?
You really ought to check the fuel pressure, guessing isnt going to help.
Old Mar 23, 2011 | 07:14 PM
Im not sure what letter it is, just know its a non-vortec, the fuel pump is two days old and working properly, gauge i looked at read just over 14lbs. Auto parts ppl said is should be between 10-15 with the throttle body injection system. When i pulled the fuel line off of the injection system, it sprayed pretty good cause there was quite a bit of pressure in the line. To give ppl a heads up, im definitely not a mechanic, just not in a financial situation to take it to the shop, especially after dropping the 200 i already put into it
Old Mar 23, 2011 | 08:32 PM
DefBlazer's Avatar
DefBlazer is on a distinguished road
It sounds like your saying it's TBI which if i'm not mistaken is the "Z" engine thusly indicated by the Z in your VIN number at least mine is that way.
What your describing sounds like you need to be looking in the electrical system and find out what looses power when falling back to the "on" posistion if you have a friend and a voltimeter or multimeter or even a circuit tester have your friend start it while you test the wires on your injectors when he/she releases it to the on position does the injector circuit die.
Do the same at the fuel pump. Find a lead going to the fuel pump and make sure it's getting power in the on position as well as start. I'm not very knowledged on the whole fuel system for these, Yet.
So hopefully someone else here can help point out more to check with and what your findings will indicate. but this would help narrow your problem down a bit.
Tell us what yuo find I'll keep an Eye out for answers while i'm trolling for a clue as to whats goin on with mine.
Old Mar 23, 2011 | 08:38 PM
sounds good, thank you
Luke92S10Blazer
Feb 6, 2010 04:24 PM
Rubes
Jan 8, 2010 09:15 PM
89blazer89
Feb 20, 2009 12:57 PM
wesmagyar
Jan 24, 2008 10:28 PM
