-   1st Generation S-series (1983-1994) Tech (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/)
-   -   Need help ASAP!!!! (https://blazerforum.com/forum/1st-generation-s-series-1983-1994-tech-40/need-help-asap-66369/)
89Recon Dec 27, 2011 05:17 PM
Need help ASAP!!!!
Here is the situation I did a Seafoam treatment on my blazer about a month ago due to it running badly and it worked perfect but the past 2 days it has been running like complete junk like worst then it was before and I would Seafoam it again but it says to only do it once every 10,000 miles are there any other suggestions to help me get my rig running better it is not getting a lot of power and it makes these popping noises and stalls out this all mainly happens when I am going up hills or going slow please help this is my daily driver
xgiovannix12 Dec 27, 2011 05:22 PM
I start diagnosing the fuel system
96+ Fuel System Diagnosis - Blazer Forum - Chevy Blazer Forums
did it rain recently by you ? any ses light ?
warthogdriver Dec 27, 2011 05:22 PM
did you seafoam the intake oil and gas...or just one of the three??
when was last time you did tune up or fuel filter....we need some history please.
xgiovannix12 Dec 27, 2011 05:23 PM
opps you have a tbi the fuel system diagnoses is the same
the pressure should be 15 to 16 psi when you turn the key on
89Recon Dec 27, 2011 05:49 PM
I seafoamed the gas and also put it in the brake booster line only thing I didn't do was the carb the fuel filter was replaced around the same time I did the seafoam treatment it also had an oil change within the last 300 miles hope that helps
swartlkk Dec 27, 2011 05:50 PM
TBI fuel pressure spec is 9-13psi for his application, not 15-16psi. Following your numbers could lead to unnecessary replacement... Best to check your facts before posting. Also, a TBI fuel pressure test port 'T' adapter is necessary to test system pressure on a TBI engine; installation of which requires the main fuel line be disconnected from the back of the throttle body & the adapter installed in-line. A test port was not provided on a stock TBI fuel system.
89Recon Dec 27, 2011 05:52 PM
that diagnosis seems to be a lot of work and it probably requires equipment that I don't have and yes it has been raining for the past 2 days here but I don't see how that will effect anything it has been rained on before with no issue and what is an ses light ?
I googled ses light and to answer your question no there has not been any lights or anything out of the ordinary
xgiovannix12 Dec 27, 2011 05:55 PM
My mistake your correct
its possible moister got into the dist cap causing the truck to misfire
and the ses light is the service engine soon
swartlkk Dec 27, 2011 05:55 PM
Problems when it's wet/humid out could indicate an ignition system problem. Once it's dark out, park in an area where there is next to no light outside. Using a spray bottle, mist down the wires & distributor area with the engine running. If you see a light show, spark is leaking from one or more of those components (wires/cap). Aftermarket caps & rotors have been known to have problems in damp conditions when used in these vehicles. If the cap/rotor were recently replaced with an aftermarket replacement, that is where I would start.
89Recon Dec 27, 2011 06:40 PM
only thing I have replaced has been 2 of the spark plug wires because they were frayed and brittle and that is when I changed out all my plugs I haven't messed with the cap or anything else only thing I can think of which is kind of weird is that 2 of my plugs have popped out on me one did it after I started driving just popped all the way out and I had to stop and put it back in and tighten it down again 2nd time it was the one directly behind it which was more of a pain in the ass but I had to put that one back in too luckily no other plugs have popped out but could that be a possibility my plugs not being tightened enough ? I am going to do the spray bottle thing here in a few minutes it is dark already so I will try that.
