Need Help Not Idle..lol...
Old Apr 20, 2008 | 05:59 PM
drgonzo's Avatar
drgonzo is an unknown quantity at this point
Default Need Help Not Idle..lol...
I have a 94 4.3 vortex.
Symptoms
Strong sulfur smell
Runs great until warmed up (5 minutes),no-little response from the gas and reduced power.Idles great and will rev up fine in neutral and park.
Changed plugs and wires and cleaned egr(again)
o2 sensor?
Cat?
IC?
Where should I start first?
Thanx in advance for your replys
Old Apr 20, 2008 | 07:34 PM
94blueknight's Avatar
94blueknight is on a distinguished road
Default RE: Need Help Not Idle..lol...
what were ur spark plugs like? and have u noticed bad mpg? could be the spiders or the fuel line in the plenum has a leak.
maybe something like this
Old Apr 20, 2008 | 07:51 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
clogged catalytic converter (The triple c effect...)
Old Apr 20, 2008 | 08:24 PM
drgonzo's Avatar
ORIGINAL: 94blueknight
Plugs were a little carbed up,not burn't or anything>i just bought it so I really didn't notice mpg.I really hope its not the spiders when hooked up to a computer it doesn't read any code but it is running rich.It only gets bad after Ihave beendriving for 5-10 mins and it reaches normal running temp.I will have to accelerate very slowly or it will buck and sputter,but wont stall.If I pull over I have no problem starting it or reving to high rpm.
Thanx
Old Apr 20, 2008 | 08:28 PM
drgonzo's Avatar
ORIGINAL: 2002XTREME
I really hope so That would be alot better than the $400 spider injector.I don't have to worry about emmissions so a piece of rebar and a hammer would be alot cheaper.
Old Apr 20, 2008 | 09:13 PM
thegr81's Avatar
I strongly suggest changing out your catalytic converter, thats were the sulfur smell is coming from!!!
Old Apr 20, 2008 | 11:08 PM
rriddle3's Avatar
ORIGINAL: drgonzo
I agree with the bad cat diagnosis. You may not have to pass a State emissions test, but if you drive it on the streets in the USA, Federal law requires a working catalytic converter.
Old Apr 22, 2008 | 11:03 AM
drgonzo's Avatar
Put on a new cat,still have same problems
Old Apr 29, 2008 | 04:07 PM
drgonzo's Avatar
Just replaced lower intake and spider,Someone had broken the egr mount.After new cat,intake,egr,and spiders.Found out I need Fuel pump.You can see on the pics that the spider was leaking.Hopefully this will fix everything...This thing is a bigger money pit than my house.
Old Apr 30, 2008 | 07:34 AM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
doesnt look like the spider was leaking more like the FPR (Fuel Pressure Regulator) and that could be a reason with your CAT. Just becasue you replace that CAT doesnt mean your problem is solved there is always a reason why they go and you should always trace it back to why its happening. It was dumping extra gas though as you can see its more clean.
G-FLo
Aug 15, 2011 09:55 PM
kyle.c
Oct 17, 2010 01:11 PM
paulsavage33
May 12, 2010 06:54 PM
Nizm0
May 2, 2010 07:57 PM
buck8907
Sep 17, 2009 06:15 PM
