no fan
Old Jun 28, 2010 | 01:45 PM
joemrmold's Avatar
joemrmold is on a distinguished road
Default no fan
hello, i have a 1990 s10 blazer. the fan motor stop working after a few minute when using a/c. the compressor kicks on and he fan will work on all speeds for a few minutes then stops. i still hear the compressor but no fan. is there a relay or something that controls the fan speeds? any help would be appreciated. i need a/c for summer. thanks
Old Jun 28, 2010 | 11:07 PM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
Yes there's a relay but check the purple wire going to your fan when it stops. No volts, fan bad. Pull it out and see if you have something making it stick. If not replace it.
Old Jun 28, 2010 | 11:32 PM
azaviator's Avatar
azaviator is on a distinguished road
I second the purple wire. I had this same problem and checked that wire. It was receiving power. Turns out that its connection to the fan motor was slightly tweaked, causing it to work intermittently. I reshaped the connector on the purple wire and reconnected it. It's been going strong for 15 months. Best of all, it was a FREE fix!!
I disagree with the "No volts, fan bad" comment. If no volts, then you have a short somewhere BEFORE the fan connection. If you have power on the purple wire, then it could be the connection (easy to test if you run a wire directly from the battery to the fan, though the sparks and jump of the fan may scare the crap out of you!!), or the fan is bad.
Let's hope for the free fix!
Old Jun 29, 2010 | 09:53 AM
Don't know what I was thinking. No volts, time to check for bad relay or broken wire or bad switch. Thanks for keeping me straight Azaviator. I'm usually better than that.
Old Jun 29, 2010 | 07:20 PM
joemrmold's Avatar
thanks got the fan to work but have a problem with air coming out of vents
Old Jun 30, 2010 | 12:17 AM
azaviator's Avatar
What's the problem? No air? Not enough air? Too much air? Smelly air? Not enough info to go on.
Old Jun 30, 2010 | 12:19 AM
azaviator's Avatar
No prob, we all have a bad day sometimes!!
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
valeria1782
Jan 24, 2011 04:12 AM
upblazer95
Nov 16, 2008 03:20 AM
