no fire
Old Oct 21, 2010 | 03:09 PM
georgia_boy79's Avatar
georgia_boy79 is on a distinguished road
Unhappy no fire
ok here is my problem,got 94 blazer 4.3 vortec, can t get truck to fire up,here is what its doing,its getting fire from the coil,i took the wire of stuck plug in it nice blue ark,it will sometimes get fire to the pluggs but not constantly,the truck hasnt started in 2 months,things that i have replaced fuel pressure regulator,coil,cap,rotor,icm,pick up coil,i am stumped,i am thinking maybe i didn't time it right when i put distibutor back in,i forgot to mark it,an dont real know were #1 is on the distributor,i just need some help
Old Oct 24, 2010 | 09:18 PM
Sparky's Avatar
Sparky is an unknown quantity at this point
You'll need to bring #1 cylinder up on compression stroke and line the mark on the balancer to TDC on the timing tab. Remove #1 spark plug and bump the engine slowly till it blows out the plug hole. Turn the crankshaft by hand to Line the mark up to TDC. With the distributor cap removed the rotor is now at a location for #1 plug wire. If you got the distributor off when you installed it, you can now use this location for #1 plug wire. Then just follow the Firing order clockwise around the cap with the rest of the wires.
When you get ready to set the timing with a timing light to get it perfect in time, there is a wire under the carpet on the passenger side floor. Pull down the carpet top edge under the dash below the glovebox an you will see a single wire with a splice plug sticking out of a bundle of wires. Disconnect the plug to set the timing with a timing light. When you get it set, plug the plug back together.
tall_ish
Nov 20, 2010 09:05 PM
john
Feb 7, 2007 12:43 PM
XBlazer01
Oct 14, 2006 11:23 AM
dashyman
Jul 24, 2006 06:43 PM
02 Vortech
Jan 15, 2005 06:33 PM
