General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
95 Blazer 4.3 Will Not Fire
Old Jul 24, 2006 | 10:07 AM
dashyman's Avatar
dashyman is an unknown quantity at this point
Default 95 Blazer 4.3 Will Not Fire
I have a 4.3, 1995 Blazer. The book says that it is CPI version. New fuel filter and pump and I have spark at the plug - infact if I give it a little starting fluid it runs for a couple of seconds.
The car will not start it cranks but does not fire - there does seem to be a short instantaneous attempt tostart on the initial key turn, but thats it. It will crank and crank - I smell no gas under the hood. My thoughts are that it is fuel related but I am at a loss as to what it might be and where to start looking.
Any help is greatly appreciated as my wife has been on my *** for a couple of days now to get this resolved.
Thanks
Old Jul 24, 2006 | 06:27 PM
Dan's Avatar
Dan
Dan is an unknown quantity at this point
Default RE: 95 Blazer 4.3 Will Not Fire
I am having the same problem out of my 93. I have replaced the fuel pump, Filter, put new plugs, wires, cap, and rotor and it still wont run unless I dump gas down the intake. Now that I have replaced everything else I bought a new Spyder that should be here tomorrow. I got a good dael on the unit at www.lindertech.com/reconinj.htm. Once I get it put in I will Tell you if it worked or not but in the meantime here is the one I bought. All together with the Core charge and shipping it costs $360
4.3 CPI Service Kit
Part# CPI-200
LTS introduces the General Motors 4.3L service kit. “Buy it all at once” This kit is just what you need for the 1991-95 4.3L “W” engines when you have diagnosed them as needing a new CPI unit. It includes an LTS reconditioned CPI unit with upgraded regulator so you don’t have any more worries about a leaking fuel regulator, the fuel supply & return lines which will put your mind at ease when removing those brittle plastic lines from the old unit, an upper plenum gasket and an EGR screen-type gasket to take care of the common problem of carbon getting stuck in the EGR valve. This is a 10% savings over purchasing these parts separately. Keep in mind, there is a $50.00 core charge for the CPI unit.
$300.00 each
Call LTS to order! Ordering Information
Telephone
(317) 487-9460 or
Toll Free outside of IN: 888-809-FUEL(3835)
(ask for Doug)
FAX
(317) 487-1868
Postal address
4-D Gasoline Alley, Indianapolis, IN 46222
Email
Information: injectorinfo@lindertech.com
Old Jul 24, 2006 | 06:36 PM
dashyman's Avatar
Thanks - that would be my last resort - I think the pump may be shot - when I cracked the fitting on the fuel filter (the new one) after a couple of cranks the fuel dribbled out instead of spraying - so the pressure is suspect. -I need to locate the schrader fitting to check the fuel pressure - I'm afraid its mounted on the fuel rail under the intake.
Old Jul 24, 2006 | 06:43 PM
Here you go:
Should be located directly off the back of the upper plenum on the fuel supply line right before it goes into the intake plenum.
[IMG]local://upfiles/667/82BBBD117B8E408D8A944635393D3DFA.jpg[/IMG]
Friday9158
Feb 21, 2014 11:05 AM
gatfrig
Jun 12, 2013 05:54 PM
spotteddog
Feb 3, 2013 09:47 AM
IrMike209
May 18, 2012 11:13 PM
tall_ish
Nov 20, 2010 09:05 PM
