no fuel pump,headlights, or radio?
Old Jun 10, 2011 | 10:52 PM
rmitch's Avatar
rmitch is on a distinguished road
Question no fuel pump,headlights, or radio?
I have a 1986 s10 blazer 4x4 and all the sudden I lost power to fuel pump, head lights and radio, but the starter still works! Any ideas what it could be? Thanks
Old Jun 11, 2011 | 04:24 AM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Get a wiring diagram. See if the things that lost power are all on the same circuit. If so, I'd check the fuses on those circuits. If the fuses are good then check for proper grounds and voltage on each circuit.
Old Jun 11, 2011 | 07:37 PM
xgiovannix12's Avatar
it could also be the ignition switch but i dont know if they run into probelms that late in year
Old Jun 11, 2011 | 08:43 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
i think ignition switch problems usually happen in the 2nd gens. but everything you described makes it sound like the ignition switch so its possible im sure.
Old Jun 12, 2011 | 12:13 AM
rmitch's Avatar
Thumbs up
Thanks for all the advice , it turned out to be a burnt wire coming off starter! It was hidden and very hard to see, but it look like the exhaust burnt it and grounded out! Again thank you all! Rmitch
BouncingRadical
14
Nov 27, 2015 12:30 AM
hollywoodgrad
Jan 25, 2012 01:58 PM
cide
Nov 7, 2009 01:26 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
