no oil
Old Dec 15, 2006 | 05:35 PM
FImports's Avatar
FImports is an unknown quantity at this point
Default no oil
i removed my torque converter cover and found no oil,which means its not my rear main seal,thank god.i also checked the oil pan no leak.i have no clue where its coming from.did notice the oil cooler line was leaking would oil from there reach the starter or is a vavle cover
Old Dec 15, 2006 | 05:36 PM
20Blazer00's Avatar
Default RE: no oil
Yes it can...
Old Dec 15, 2006 | 05:40 PM
FImports's Avatar
Default RE: no oil
thank you
Old Dec 16, 2006 | 12:11 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: no oil
the oil cooler line runs under the engine from the drivers side remote filter and under the engine by the drivers side motor mount. which would make it hard for oil to reach the passenger side mounted starter. and the internal cooler line is also on the drivers side of the rad. although these compression fittings do spray more then leak under driving conditions, so u never know. but chances are its not the oil lines. now if those lines are in fact leaking then u should change them, they are actually quite important as far as pressure and flow to/from filter. once again that area of the valve cover is hard to see. being that the cost of a gasket is fairly cheap and easy, then u should just due them anyway. plus check the torque on the starters bolts, sometimes oil will lubricate the bolts loose.
Ak95Blazer
Jan 7, 2009 06:56 AM
todaresqSL2
Nov 10, 2008 01:47 PM
FoxTrota
Aug 13, 2008 07:24 AM
shooter2499
Feb 4, 2008 09:23 PM
KA3AX
Jan 15, 2007 01:33 AM
