No reverse, 94 S10 Tahoe Blazer
Old Jun 15, 2012 | 07:41 PM
JayDee240's Avatar
JayDee240 is on a distinguished road
Default No reverse, 94 S10 Tahoe Blazer
I recently acquired a 1994 Chevy S10 Blazer 4 door 4x4 automatic. I bought it from a friend for $400, knowing that it had a transmission problem. He says he was driving in the rain trying to "drift around corners", and running the thing really hard. He got home and realized reverse stopped working. Basically it shifts fine through all gears, but when it's put in reverse, the reverse lights come on, the engine RPMs drop, but it just stays neutral. Also, the "PRND12" marker is off. P is park, in between P and R is "reverse", but then R is neutral, N is drive, D is 1st, and so on. So I don't know much about transmissions. Could the linkage be off? From what I've worked with in the past, if the linkage is off, there's no park. Or is the reverse gear shot? The fluid is burnt and low, but I didn't bother changing it in case I definitely need a rebuild. It hasn't even slipped into reverse since the incident, just no reverse at all. Before the "Tokyo drifting" reverse worked fine
Old Jun 17, 2012 | 11:52 AM
workshop4ever's Avatar
workshop4ever is an unknown quantity at this point
Linkage could be off just enough to cause these issues, but low/burnt fluid can cause this as well. I would start by changing the fluid and fixing the linkage.
jdoerrer
Oct 15, 2007 01:11 AM
Lockback
Aug 22, 2007 12:24 PM
evansblue24
Nov 24, 2006 06:24 PM
cooter
Tires and Wheels
Oct 7, 2006 03:46 AM
Mariongo
Aug 31, 2006 12:52 PM
