No start blues
Yeah you just get the harness at the parts store, but the ones in my country have no listing for it for these V6 engines. It is the exact same part as on the V8 motors, which there is a listing for.
Just ask the guy for the injector harness for a 94 half ton with a 5.0 or 5.7, he will tell you that he has them in stock, and its about 10 bucks. And its going to come with this rubber grommet that you probably found little slimy bits of when you took off your old one. Its got a white connector, and red/blue wires about 14 inches long.
When you cut off the old harness, make sure you do the soldering on the outside of the engine, not inside the intake. Make sure there is lots of slack on the inside so the new connector isnt getting pulled and tugged on in anyway.
So I called every part store locally and same issue everyone else saw that it is listed wrong.... at JCWhitney I found it but then it gives three options for the part none which are listed for the 95, center slot with release, center slot without release and offset release... http://www.jcwhitney.com/fuel-inject...DetailTabPanel
Any idea which of the three? sorry to be a pain.
If you put in it being for a 1994 s-10 and click on "select options" it gives you a list of the available ones 3 have the W code, Im pretty sure its the center WITH release any confirmation?
Crap Blazer
14
09-21-2009 12:46 AM
KdogTN
09-28-2008 05:38 PM
