No Start.. Stall.. Backfires Through Throttle Body..
Old Jan 12, 2009 | 11:48 AM
metalhead's Avatar
metalhead is an unknown quantity at this point
Default No Start.. Stall.. Backfires Through Throttle Body..
ok i'm posting this as a third party as my dad is computer illiterate lol..
he has a 1989 S-10 Blazer 4.3L 4x4 and has been having some issues for the past week or so.. first off sometimes the truck won't startso he has to pump the gas pedal to get it to start.. it'll start then but will run with a rough idle.. sometimes even spitting up/backfiringthrough the throttle body..
also if he's driving it for awhile he can't shut it off when it heats up because it won't start again..
and while driving the truck runs pretty crappy..
he's changed the fuel filter, plugs, distributor,cap & wires, and the coolant temp sensor.. still to no avail..
any ideas anyone..??? he doesn't think it's the fuel pump so we're baffled... THX in advance for any and all help
Old Jan 12, 2009 | 11:53 AM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
Default RE: No Start.. Stall.. Backfires Through Throttle Body..
Have you tested the fuel pressure? It's a TBI, right? It should be 9-14 psi if so.
When he changed the distributor, did he make sure it was installed correctly? Even one tooth off can mess everything up. How did the plugs look? Were they wet, oily, black...?
Pull and clean the EGR valve, making sure there's no carbon holding the pintle open, and clean the passage behind it.
Old Jan 12, 2009 | 12:20 PM
rriddle3's Avatar
I would have the ignition coil tested.
Old Jan 12, 2009 | 12:22 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
ORIGINAL: Leeann_Bravada
and grab a screened gasket for it for reassembly to alleviate this happening again.
Old Jan 12, 2009 | 05:12 PM
metalhead's Avatar
problem fixed... turned out it was the fuel pump relay was gone.. THX guys
Old Jun 5, 2009 | 02:02 PM
blazersforlife's Avatar
blazersforlife is on a distinguished road
metalhead where is the fuel pump relay at, cause me and my dad are having the same problem.
chuckiesob56
Dec 27, 2014 03:00 PM
A1 Handyy
Jun 13, 2014 03:13 AM
jbb421
Jul 16, 2012 03:08 AM
drew_fur
Jun 8, 2011 03:52 AM
Taymacjack
Nov 20, 2008 08:11 PM
