noisy altenator
Old Nov 23, 2011 | 04:13 PM
4uzindian's Avatar
4uzindian is on a distinguished road
Default noisy altenator
1988 v6 4x4 blazer has a sound that comes from altenator like somethings loose .i think it's the altenator bearing. can it be rebuilt and if so where is the info i need to order a new bearing for whatever model it might be ?
Old Nov 23, 2011 | 05:07 PM
pettyfog's Avatar
https://www.google.com/search?q=chev...or+rebuild+kit
But I dont recommend it. Because if the bearings are bad, no telling what shape the rest of it's in.
Go to salvage yard and get a used one - just like yours- over the counter. The better yards sell the better stock first. And get a brush set from NAPA.
Spin the alt while it's on the counter and make sure it's nice and quiet while turning free. Compare to the one on your truck. Bearings should not sing and the shaft should have no side and very little end play. Put the new brushes in the one you just bought.
look close at the rectifier assy and especially for burnt looking places. Between the two, use the parts that looks best . Dont worry about wear on the slip rings unless they've been grossly abused. Just a light sanding with fine paper will do
Put a little-fingernail size lump of lube in the back bearing. Keep alt dust out of it.
Now you will have a GEN-YU-Wine rebuilt alternator as good or better than the cheapies at AZ. Because it came off a running car, thus presumed good rather than a core turn-in. No telling how many times the AZ rebuilts have been through the cycle.
Old Nov 25, 2011 | 03:49 PM
4uzindian's Avatar
thanks for the intelligent answer. i'm going to do what you recomended. i'f i have any problems i'll be sure to make another post. so for now i'll be closing this post now.
Old Nov 25, 2011 | 04:55 PM
Please respond to this thread with your resolution. No need to create a completely new post to discuss the problem even if what was suggested was not the source.
Hunter66
18
Nov 22, 2013 08:52 AM
lefty55
May 3, 2012 03:24 PM
crater
Oct 7, 2011 06:41 PM
edski
May 29, 2007 08:36 PM
*TLR*
Apr 23, 2006 04:41 PM
