non-op temp gauge
Old Jul 12, 2010 | 07:35 PM
pinstriped blazer's Avatar
pinstriped blazer is on a distinguished road
Default non-op temp gauge
My 94 blazer overheated and sent the temp gauge to top of the gauge and then the needle fell back to the "off" position where it has stayed for sometime. I have already changed the sensor and the gauge still does not respond. Which component did i fry? What other components should i check and where are they located? Thanks in advance for the help.
Old Jul 13, 2010 | 12:33 AM
Gimpy Blazer's Avatar
Gimpy Blazer is on a distinguished road
If you pull the wire and ground it the guage should go full hot. Sounds like your wire isn't making the connection. I would check my wiring. Just overheating the engine shouldn't cause the temp gauge not to work. By the way, analog or digital gauges?
hoppy26
Jan 26, 2012 02:08 PM
zakm0n
Jan 9, 2011 07:31 PM
Malachai
Mar 27, 2010 10:00 PM
mboehler
Jan 16, 2009 07:16 AM
Mulisha
Mar 24, 2008 09:14 PM
