Not getting fuel
Old Oct 4, 2009 | 09:09 PM
treysanatomy's Avatar
treysanatomy is on a distinguished road
Default Not getting fuel
My blazer just up and died today. It restarted and ran great. Then acted up again. I can here the fuel pump. Can it be the pressure regulator and how do you check it?Please Help I am in a bad bad way as I am sure alot of us are
Old Oct 6, 2009 | 08:25 PM
Originally Posted by treysanatomy via PM
BTW, thanx very much in advance. My 89 s10 blazer just quit and when i try to start it i notice fuel coming from the injectors, i also tried to start it with starting fluid. It tried to no avail and then i searched and found this thread of yours. thanx again.
In reference to your PM, yes, you have an ICM and coil on your '89. But your engine is a TBI engine. Your fuel pressure should be 8-10psi. The catch is that you have to disconnect the fuel feed line and install a T fitting before you can connect the fuel pressure gauge.
Have you tried to start it with starting fluid? If it does not start with starting fluid, then fuel is likely not your problem. That leaves air & spark as the likely culprits.
Also, please try to keep everything in the open forums. It allows you to get responses from many people as well as helps others that may be experiencing the same problem. Always include your vehicle information as well. If no one knows what you are driving, it makes it awful difficult to respond to your problem.
Old Oct 7, 2009 | 05:19 PM
Thanx very much. I have an 89 s10 blazer that these issues concern. It tries to start with starting fluid but will not. I can see gas spurting from the injectors, not in any cone type shape. It just stopped all of the sudden with no real warning. How do i check the coil and where should I begin with the air issues...AS ALWAYS THANX VERY MUCH... GOD BLESS THE THE TROOPS
Old Oct 11, 2009 | 10:01 AM
I am trying figure out why my 89 s10 blazer will not start. Starting fluid and it tries a bit, but put a few drops of gas in throttle body and it starts. OF COURSE IT GOES WITHOUT SAYING TO KEEP AN EXTINGUISHER HANDY. This tells me its not a pump relay or fuel filter.
I have a 1989 s10 Blazer with th 4.3l. never had an issue the 1st time 5 days ago. I had to turn the key twice which was the 1st hint of trouble. Shortly afterward I started again with no problems, it ran perfect for 2hrs then it died for the very 1st time ever. i cranked and cranked and cranked, it finally started and ran terrible, sputtering, spittin and carrying on. then it died and has not started since accept 1 time for a few minutes when I started it with Starting fuel. Now it just tries to start with starter fluid. if ya put a few drops of gasoline in the throttle body it fire right up. Being the SHADE TREE MECHANIC this tells me I have fuel pump problem. How do I go about doing the SHADE TREE testing for this issue. I took the supply line off of the throttle body, turned key on and no fuel at all. Is this an honest way to test? PLEASE ADVISE I AM IN A PICKLE OF A WAY RIGHT NOW. As always folks I Thank You
I have an 89 s10 Blazer, 2wd, with a 4.3l. is my fuel pump an internal or external? I think it's in the fuel tank but my old school Dad just won't let me go with out asking. Which type and what do I neeed to purchase for the pump change without all the extra trips while doin the job. will I need to buy the strainer sock? PLEASE ADVISE..Thanx as always
Last edited by swartlkk; Oct 11, 2009 at 04:13 PM. Reason: Merging Double Posts - Please keep things together.
Old Oct 12, 2009 | 02:46 PM
Corrupt's Avatar
Corrupt is on a distinguished road
You should be able to re-use the strainer sock. Just sorta glanced threw your post but have you disconnected the line between the fuel filter and the gas tank and check for pressure there? Fuel pump is definitely in the gas tank. Fuel filter is possibly underneath the truck on the drivers side, between the middle of the truck and the rear tire tucked up in the frame. You should see the fuel line(s). Sometimes after sitting a bit the trash in a fuel filter can drop to the bottom side of the filter and then after being pressurized again will clog it back up
Old Oct 17, 2009 | 01:09 PM
I disconnected the fuel line from filter to fuel tank, i turned the key on a still no fuel was pumped nor did i hear pump back at the pump. From other info i've picked up it sounds like i need to check voltage at tank. So now I am really upside down. doesn't sound to difficult just not sure how to check. thanx
Old Oct 22, 2009 | 08:14 AM
Corrupt's Avatar
So what'd ya find out on the voltage? If not getting any voltage back to the pump, might want to check your fuses. Pay close attention when you turn the ignition key to the on position. Does everything on the dash light up that is supposed too? If you are getting voltage, sounds like it's a definite bad fuel pump. It was probably a lot easier for me to check as I have a 3" body lift. Just look above your driver side rear tire over top of the gas tank and you should be able to see the wiring going to the pump. You'll need to have a voltmeter with very sharp points on the leads. Check each wire pushing the sharpest point of the lead into and threw the plastic, making sure you are touching the inside wiring, while holding black on any metal on the truck.
Old Nov 2, 2009 | 06:59 AM
Default Voltage is good, relays and fuses were good.
I changed the filter and fuel pump. Runs like a top I am proud to say I repaired the problem I couldn't have even began without all the great responses. Thanx to all
Old Nov 2, 2009 | 08:22 AM
Thanks for the followup! Glad you got it fixed up!
Taz
Oct 17, 2009 12:21 PM
NEdeadhead
Feb 19, 2008 09:53 PM
dannydarko
May 11, 2007 09:13 PM
dirtysouthS10
Apr 16, 2007 06:22 PM
jhill133
Mar 29, 2007 08:13 PM
