Oil Pressure Drop
Old Dec 6, 2006 | 01:19 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default Oil Pressure Drop
I know I said in another post that my oil pressure goes down somtimes but I just check the dip stick and if there is oil in there I don't worry about it. But now i'm getting worried. When I start it, when the engine is cold, its running about 50-60, then when it warms up and i'm driving normal its running about 30, but when I give on er it goes back to 40. But when i'm at a complete stop when warm, its running about 15. I really don't like the looks of that. Just thought i'de ask. Thanks.
Old Dec 6, 2006 | 01:27 PM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: Oil Pressure Drop
oil pressure fluctuation is common.
when the oil is cold it doesnt flow as easily, thats why the pressure is so high when the engine is cold.
when the engine is at idle the oil pump is not spinning as fast, thats why the pressure can seem low.
i'd say 30 to 40 under normal driving is perfectly normal oil pressure.
Old Dec 6, 2006 | 02:49 PM
Yeah, if it drops below 8psi at idle, then I'd worry about it. Typically, if you can't hear your rocker arms tapping, then your bottom end is still getting good oil. Chances are your main & rod bearings are getting worn down and the additional clearance is bleeding off oil pressure.
racsan
Mar 7, 2014 10:14 PM
2dr jimmy guy
Jan 26, 2013 09:36 PM
maddogggrrr
Jun 25, 2012 07:52 PM
brianroark
Jun 25, 2010 03:14 PM
justin1795
16
Apr 25, 2009 09:25 AM
