Oil Pressure Switch Pig Tail Woes
Old Aug 25, 2010 | 06:25 AM
mr.vls's Avatar
Default Oil Pressure Switch Pig Tail Woes
The connector tab on the wiring harness was broken for the Oil Pressure Switch so I purchased a new connector (Pig Tail). To get enough room to crimp the butt splices into the harness I had to remove the distributer. (I marked the location of the rotor for reinstallation) I cut the old connector off and spliced the new connector in and hooked it up to the Oil Pressure Switch. Re-installed the distributer and tried to start the engine. All it did was crank and no start. I verified TDC and the firing order and all was correct. I then remembered that one of the wires to the Oil Pressure Switched sparked when I had stripped the wires back to splice the new connector in. I pulled out the wiring diagrams from my factory service manual and found that the fuel pump is fed from ECM B and it is hot all the time and goes to both the Oil Pressure Switch and the Fuel Pump Relay. Sure enough the fuse was popped. This was a good opportunity to replace plugs, Cap & Rotor. I replaced the fuse. The engine fired right up. Blowing the fuse really through me for a little while and I kept checking the firing order, and the distributer orientation, checking for spark. I had to stop, re-think everthing and once I did I figured I either fried the fuel pump or blew a fuse. I glad it was the fuse.
Old Aug 25, 2010 | 06:40 AM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
A great example of how taking your time and diagnosing the problem correctly can save you big time and money! Great job! But as I am sure you know now and a tip for beginners, always disconnect the battery when servicing electrical components or wiring!
Old Aug 25, 2010 | 07:10 AM
mr.vls's Avatar
Yep, not removing the battery ground caused me some unwanted frustration.
addzradd
Oct 24, 2012 01:11 PM
Sam's rustyY2K
Headers, Intake, & Exhaust
Jan 28, 2012 01:21 PM
sidviscious
Oct 8, 2009 08:38 PM
Pee_Beds
Apr 4, 2009 03:53 PM
guywm25
Apr 10, 2008 04:36 AM
