Overwhelmed!
Old Jun 8, 2013 | 10:41 AM
airwolf's Avatar
airwolf is on a distinguished road
Default Overwhelmed!
I have a 93 s10 blazer 4.3 Vin W. Started hesitating last week while driving. Acted as though it was about to die several times. I have good strong fuel pressure and plenty of spark at the coil and plugs but it still won't start. Could this possibly be the ECM?
Old Jun 8, 2013 | 07:25 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
define good strong fuel pressure.
Old Jun 10, 2013 | 09:40 PM
airwolf's Avatar
It's about 64 per my pressure tester
Old Jun 26, 2013 | 01:12 PM
eagle1971's Avatar
eagle1971 is on a distinguished road
Believe it or not, I would check the EGR valve. I had a 95 and a friend had a 94 S10 4.3L that kept gumming up the EGR. That would make the engine to almost stall when idling.
Old Jun 26, 2013 | 08:18 PM
richphotos's Avatar
How long does it take for the 64psi fuel pressure to leak down? 64 is a bit high, 60-62psi is normal.
Is it throwing any check engine codes?
Old Jun 30, 2013 | 01:26 PM
airwolf's Avatar
I finally got it running. I removed the DVD valve, cleaned it, and replaced the old gasket with one that had a screen. I also replaced the fuel pump, fuel filter, plugs, plug wires, distributor cap, rotor, ECM, the fuel pressure regulator, and finally the spider injectors. After I replaced the spider I have had no problem whatsoever. Ugh, I hate this gm design.
HcHawks09
Lifting Tech
Apr 9, 2010 01:53 PM
