PCV Valve and Valve Cover ?'s
Old Oct 22, 2011 | 04:34 PM
89Recon's Avatar
89Recon is an unknown quantity at this point
Post PCV Valve and Valve Cover ?'s
I have a 89' s10 Blazer with a 262 and I had to replace the valve covers I have gotten the p/s replaced *note- this is when looking at the engine from outside the vehicle* I still need to replace the d/s I just want to know why the little black pieces that hold in the valves won't fit back in? so do I need to replace them or is there a trick to putting them back in?
Old Oct 22, 2011 | 05:50 PM
abig84's Avatar
the black grommets that the pcv's go in? those should be like soft rubber. over time they turn into hard plastic so yeah id replace them cause even if you get them back in they will probably still leak. if they arent hard then lots of lube
marksoftball
Nov 29, 2014 09:27 PM
kancop
Feb 17, 2014 08:06 AM
K1500brute
Mar 14, 2012 04:04 PM
Resolute
Dec 25, 2007 03:58 PM
blazinloud
Engine & Internal
Sep 14, 2006 12:08 AM
