Please Help, Fuel Pump Problems? Very Odd...
Old May 5, 2009 | 11:10 PM
rriddle3's Avatar
The OBD1 system would not specifically detect a shorted wire. Here's a list of OBD1 codes.
Old May 5, 2009 | 11:21 PM
joeroket's Avatar
joeroket is on a distinguished road
In my experience the fuel system does not throw a trouble code. Hell even a broken CPI power connector did not throw a code when I ran it on ether.
A code 12 means that your system is functioning normal.
Old May 6, 2009 | 06:49 AM
Start with the basics. Since you cannot hear the pump start, you should see what power is actually getting back to the pump. If you are not getting full battery voltage and have a good ground to the pump connector and the pump still does not run, then the problem is with the pump.
Did you have to put a new connector on the wiring when you installed the new pump?
Tazzorn
31
Apr 23, 2014 07:38 AM
jimhens82
Apr 20, 2014 07:37 PM
DFEMS2
Sep 5, 2010 05:40 PM
88hurstolds
Feb 26, 2009 09:41 PM
rogggg1020
Nov 11, 2008 08:05 AM
