HELP!!! very odd and coincidence no start
Old Apr 19, 2014 | 03:32 PM
jimhens82's Avatar
jimhens82 is on a distinguished road
Default HELP!!! very odd and coincidence no start
So I have my 02 4dr 4x4 in the drive way I replaced the plugs cap rotor and distributor.... Set cyl 1 at tdc right by the book !! So when I drove it from work it showed half a tank of gas before I started on the work.... So I get it together n go to crank it no start !! So I pulled it all did it again no start I then realize that my low fuel light was on which was odd Cuz just had half tank so I put 2 gallons in it and gauge never moved ... So I put my fuel pressure gauge on and nothing ... The pump has been done but is there something I could have done while doing the dist,cap,rotor ??? Its just very very odd that the sender and pump quit at same time I'm an auto tech too!!! That's how I make a living exc its on fords ! And I'm stumped help me out guys please !!! Lol
Old Apr 20, 2014 | 12:04 PM
Gmas95's Avatar
Gmas95 is on a distinguished road
Do you hear the Fuel pump when you put the key to the on position? You should here it for 3 seconds. If you do not hear it, check to make sure it is getting voltage to the sending unit.
Old Apr 20, 2014 | 07:37 PM
jimhens82's Avatar
Its not the pump .. I found the ecm b fuse blown changed it pump came right on ..so its something with the distributor cap n rotor and cam sensor I put in
klote82
Apr 27, 2012 08:22 PM
kiwiblazer
Feb 3, 2011 09:49 AM
DFEMS2
Sep 5, 2010 05:40 PM
88s10Blazer
Mar 2, 2010 10:00 PM
Raanerud
May 6, 2009 06:49 AM
