Power window regulator help...
My power windows pop when rolling them down. The passenger side is so bad that it ends up rolling down diagonally and gets stuck. My mechanic said the problem is most likely the window regulators. He said if I can do it myself it'd be worth it to do so. He suggested going to a junk yard and finding a pair.
The problem is, I have no idea what to do. I've never replaced them before. Is it difficult? Also, sometimes the switches don't work when trying to roll the windows up/ down. Any ideas what the problem may be?
It likely is not just the regulators, but a combination of the regulators and the window tracks (what holds the window side to side while the regulator pushes it up and down). The popping is likely the regulator skipping teeth, but from the sounds of it, that is because the window is getting jammed inside.
Working on the windows can be frustrating. I just redid the window regulator and tracks in my '74, but I have done a few in the past. My advice would be to get in there and see what you can see. Watch everything and try to determine where it is falling off first. All of the tracks should be solid and should not move so start with that. You will need to remove the door panels as a first step.
the regulator isnt that hard to replace, and as far as the switch not working, test the switch to be sure its the problem otherwise its the motor. i just got a motor for mine for $40 at autozone new so thats not bad either alil drilling and four screws later done.
I agree that it will likely be the window tracks. As far as the window motors, I believe they go on most of these trucks, so that may explain them intermittently working. You can check the tracks by seeing if they move any by grabbing them and watching them as the window moves up and down. They should be solidly mounted. I had an issue with my driver's window, the window would roll up crookedly and make a popping noise like you described. The window track near the top of the door was loose. Aparently there should be a screw in there that fell out over time, allowing the window to rollup crookedly. One screw later and the window goes up/down like it should.
By tracks we mean the channels that the window rides in at the front and back of the window frame. They extend down into the door and keep the window in the proper position for the regulator to do its job. If the window is cocking in the door, then I would suspect a bad track inside the door. The tracks should be nice and straight.
Ok, that's what I thought you meant. The window rolls down, pops, then the front starts dropping. Is it possible that the window is out off the track like this: http://www.honda-tech.com/showthread.php?t=2061336
blanco36
Jul 30, 2012 07:56 AM
Turtle64
Jun 22, 2010 09:44 PM
my 88
May 16, 2010 05:36 PM
