problem charging
Old Nov 27, 2008 | 10:46 PM
redride's Avatar
redride is an unknown quantity at this point
Default problem charging
On my 87 K5 Blazer at idle it doesn't charge at higher RMPs it charges at about 14 to 16 volts.
I have a new red top optima and a new high amp Alt. What else could it be?
Old Nov 28, 2008 | 06:54 AM
salvy's Avatar
salvy is an unknown quantity at this point
Default RE: problem charging
Is it a rebuilt alt ? maybe a bad voltage regulator.
Old Nov 28, 2008 | 07:35 AM
You should not be getting voltage that high out of the alternator. It definitely sounds like the voltage regulator is bad.
Old Nov 28, 2008 | 08:24 AM
redride's Avatar
I will take it in a get it tested. I think that it is rebuilt. I'm going to go through and redo the ground contections. Thanks
got it tested and the regulator failed. got a new one and truck running good. Thanks again!
beast1978
Oct 12, 2014 02:48 PM
ck81144
Jan 3, 2013 08:43 PM
Charibdis
Feb 27, 2012 09:43 PM
modifyyy87
Oct 14, 2010 09:10 PM
odfareal
Nitrous, Super Chargers, & Turbos
Oct 26, 2009 01:36 PM
