proportioning brake valve missing
Old Sep 17, 2020 | 02:19 PM
Koteli's Avatar
Koteli is on a distinguished road
Default proportioning brake valve missing
Hi all
refurbishing my chevy , after installing new brakes lines from MC ( Master Cilynder) to chassis conection I realised or I think that someone , old owner , remove this part and threw it away , streched the lines to reach MC and he installed one low pressure release valve on rear lines.
I checked information on GM and the PN is 14041636. the problem now is how to find it in Spain, not many cars like this one in scrap yard
the new installation, but may be need modification inserting the proportioning valve.
scrapyard ..Maybe importing from USA (RockAuto, Amazon, Ebay) or from China ( Aliexpress) .
I review information about it and it is like a Pre-ABS
is a good idea to reinstall it ?
any suggestion ?
thanks
Old Sep 17, 2020 | 08:28 PM
The easiest way would be to install an adjustable valve in the line to the rear brakes. You can also buy a whole combination valve and run all the lines through it.
If you get the combination valve, make sure you get the one that matches your rear brake setup (disc or drum).
Old Sep 18, 2020 | 02:41 AM
Koteli's Avatar
Default proportioning valve
I checked the PN on GM web site and it apply on my car,it is a type PV2 Disc/Drum .there is other type, PV4 for Disc/Disc.
I think it is a benefits for the car to use the proportioning valve.
All the old cars has this valve in USA ?
in Spain I have never seen on it, neither the release valve.
old line with release valve inserted
Old Sep 18, 2020 | 08:34 AM
Koteli's Avatar
Default Adjustible valve
Tom , I am afraid about the adjust of a new adjustible valve , may be that kind of valve is more realivable and efficient but the adjustment may be complicated. Is it not ?
Old Sep 18, 2020 | 12:09 PM
It should be fairly simple, but I have never actually done it, so I can't say for sure.
Eddie Boot
Aug 27, 2018 03:21 PM
keyonn
Apr 2, 2014 05:24 PM
FalconPunch310
Oct 19, 2012 06:28 PM
88 rusty but trusty
Feb 16, 2011 10:38 PM
wwilly1968
Jan 19, 2011 09:12 AM
