Question about replacing a catalytic converter(88 S10 Blazer)
Old Aug 5, 2013 | 01:58 PM
CDiablo's Avatar
CDiablo is on a distinguished road
Default Question about replacing a catalytic converter(88 S10 Blazer)
My cat (again on an 88 Chevy S10 Blazer 4.3L) went and I am replacing it the 2 parts that connect opposite of the input side of the exhaust are this and this(there is a bracket that slides over the pipe). When taking off my old piping there wasnt anything holding those pipes together other than 4 bolts that connected their respective brackets. Is there anything that goes between the metal to make a tighter fit(gasket or the like)? Thanks for reading and helping all.
Old Aug 5, 2013 | 03:25 PM
richphotos's Avatar
I believe there is a gasket that goes in there, search exhaust flange gasket.
Old Aug 6, 2013 | 02:06 PM
abig84's Avatar
i should know this for as many as i do... i dont think so if i had to guess. if you look at the two pieces it looks like they should into each other but yeah hard to tell without looking at it
Old Aug 9, 2013 | 09:53 AM
CDiablo's Avatar
I was able to figure out that there is no other piece between the pipes. The exhaust flange gasket is a part you can attach to the outlet on a universal cat to give it the bubble end that is on the cat I linked to on my first post. It does not come with the plate that helps make the bond between the cat and the midpipe. I could not find one for sale so I guess you would have to find a new one(couldnt find it) or use the one from the previous cat. Thanks again for the help guys.
LannyL81
Nov 4, 2013 02:23 PM
lkrides
Mar 29, 2011 10:55 PM
matthew.chapman1
Headers, Intake, & Exhaust
Oct 26, 2009 07:58 PM
dillonml
May 24, 2008 12:15 AM
yazan84
Mar 10, 2008 06:53 PM
