rattling rear window
Old May 3, 2007 | 07:49 PM
nbwebb's Avatar
nbwebb is an unknown quantity at this point
Default rattling rear window
i know the rear window rattle/squeak is a popular annoyance with these. i usually quiet mine with some electrical tape around the piece on the window. this works for a few days, then is all ripped and i wrap it again....... anyone got better ways to fix this prob???
Old May 3, 2007 | 08:20 PM
Default RE: rattling rear window
You can try to adjust the latch to pull the window into the weather stripping more... That will tighten it up. There should be an adjustment. On my Bravada I had to remove the interior trim panel to adjust mine.
Old May 3, 2007 | 10:38 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
I use WD40 on the weatherstripping, seems to help it from drying out.
Old May 3, 2007 | 10:49 PM
Don't know where the weatherstripping came in... but... WD40 may not be the best choice... A true silicon spray is more appropriate.
Old May 4, 2007 | 07:20 AM
Mbastet99's Avatar
Ooops, my fault....I meant on the rubber trim that the glass fits up against....
Old Jun 30, 2007 | 12:37 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
You can also tighten the actual glass hinge bolts, that worked for mine. Or just replace the glass with an 83-86 rear glass, it seems to fit a bit better on the early 90's blazers.
Old Oct 11, 2007 | 11:50 PM
joseph296's Avatar
joseph296 is an unknown quantity at this point
ORIGINAL: nbwebb
this is the most popular i think
Old Oct 12, 2007 | 10:23 AM
agent305's Avatar
agent305 is an unknown quantity at this point
i did the electrical tape thing for 3 yrs. then tightened the bolt on the glass and broke the window.
but as Kyle said... a real silicone spray worked. i had the truck another 2 yrs and never heard it squeak again.
e602
91
Mar 8, 2015 04:53 PM
01blazer4.3p
Dec 4, 2011 10:02 PM
Calgary ZR2
Jan 10, 2008 01:15 AM
dahfrenzy
May 9, 2007 04:20 PM
gibbylt1
Jul 31, 2006 01:27 PM
