Is it really necessary to get a rebuilt spider injector?
Old Jan 11, 2011 | 11:52 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Default Is it really necessary to get a rebuilt spider injector?
I am just wondering about the innards of the spider injector, if you replace the regulator and make sure all of the seals on each line to each cylinder are not leaking, can there really be anything wrong internally with the spider injector? Aside from the injector connector, is there anything mechanical/electrical that can go wrong with a spider that would make it in your best interest to replace the entire thing?
Old Jan 12, 2011 | 09:45 AM
ohsofly's Avatar
It depends. If your leak is not the spider, then I wouldnt worry about it. Mine was leaking from 2 of the poppet nozzles... So I needed an injector assembly. I just used a junkyard one for now, works fine.
Old Jan 12, 2011 | 04:42 PM
The problem that most often occurs with the spider assembly, aside from a leaking FPR, is the poppets gum up which can cause them to not open properly and/or not spray properly.
Old Jan 12, 2011 | 10:00 PM
neex's Avatar
neex is on a distinguished road
I had the main body show a hairline crack behind the FPR. It was done for. I've never really seen one shorted out and I have a few in my garage for poaching parts. You can rebuild them yourself with patience. The FPR is the most common problem aside from a failed nut kit. I've never had a varnished up or stuck poppet yet but I hear it's also common. The plastic retainers seem to break now and then as the heat cycling makes them brittle. You can buy replacements that are sold as a 'test kit' I believe.
I hope this helps!
A.
serrasalmus
Jun 12, 2012 05:57 PM
ozzygoat
Apr 26, 2012 11:36 PM
bigdaddykane93
Apr 17, 2010 01:36 AM
Matty Kling
Dec 23, 2006 03:38 PM
Ernie1019
May 9, 2006 11:19 AM
