rear window squeak
Old Nov 19, 2006 | 10:07 AM
rooster's Avatar
rooster is an unknown quantity at this point
Default rear window squeak
does anyone know why and how to stop the rear window from squeaking, it looks like the window slides sideways when i go over any bumps but squeaks all day long and is getting on my nerves. ive glued a piece of rubber to the bottom to make a tighter fit and ive tightened the bolts on top. yet squeak squeak everywhere i go. pls help
Old Nov 19, 2006 | 03:37 PM
sledneck16's Avatar
sledneck16 is an unknown quantity at this point
Default RE: rear window squeak
what you need is some sort of clear drying silicone lubricant----put some on ALL of your seals on your truck and they wont squeak until it wears off in a few months---then repeat. [8D]
oh and try not to get any on your paint---might not react well depending on what you use
Old Nov 19, 2006 | 03:46 PM
bat119's Avatar
bat119 is an unknown quantity at this point
On my 99 blazer I had the same problem, to stop the squeak I wrapped fiberglass tape around the bar that goes into the catch (2 wraps) it has held for a month so far.
Old Nov 19, 2006 | 11:30 PM
The rear window latch can be adjusted, but it involves the removal of the interior trim. Then there are 2 nuts that need to be loosened to adjust. I did a little how-to a long time ago, but it never made it into the DIY section.
Old Nov 20, 2006 | 12:01 AM
RedBlaze's Avatar
From: Atlantic, NC (eastside whats crack-a-lackin!)
RedBlaze is an unknown quantity at this point
for a quick and easy fix all i did was wrap some electrical tape around the bar that goes in the latch. if you dont open up your backglass a whole lot it will hold for a good while.
Old Nov 20, 2006 | 03:50 AM
Chevy Lover's Avatar
How about the end gate? Is it adjusted tight? I've heard of the endgate being loose between the latch and the striker, which could also cause a squeak on the window.
Old Nov 20, 2006 | 01:55 PM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
A couple shots of WD 40 in the latch, and wiggle the latch in between squirts, can work for awhile, too. An immediate fix to stop the noise until you can get around to the better fixes.
Anne
White '91 2 dr S-10 Blazer
4X4, 4.3L, automatic
Sunroof, running boards
151,000 miles
Old Dec 5, 2007 | 09:02 PM
blazinloud's Avatar
sweet!
mine almost makes me cry
wow, this thread is almost 2 years old......
Old Dec 8, 2007 | 04:31 AM
I've started simply greasing the catch which is the source of the noise in mine.
Holds as long as electrical tape or other remedy.
Old Dec 8, 2007 | 04:33 AM
dimmuborgir6nik6's Avatar
dimmuborgir6nik6 is an unknown quantity at this point
Mine never used to squeak, but tonight I noticed it's starting to.
I've also noticed that it doesn't open all the way automatically anymore. It goes up halfway and I have to push it the rest of the way up.
I think with all this snow, the rocksalt could've messed it up.
