Right brake light / turn signal
Old Nov 13, 2009 | 09:12 PM
drummerdude's Avatar
drummerdude is on a distinguished road
Default Right brake light / turn signal
so I had this issue before, but thought I resolved it. I have a 94 S10 blazer, last year the right brake light would stop working sometimes. Originally thought it was a bad bulb, but after a number of replacements in short time, I determined that I thought it was the socket itself. I spiced in a replacement socket from the junk yard (just happened to be there) And I thought my problem was fixed. However today I discovered it happening again. What really bugs me about it is when its not working, if I give it a swift smack on the side of the lens it works again. Another smack and it stops. Took the sockets out of the lens, and sometimes flicking the back of the questionable socket would make it cut in and out, but sometimes not. Is it the socket again? or should I look deeper, like a broken wire? Anyone eles have this issue?
Old Nov 14, 2009 | 11:12 PM
pidgemonkey's Avatar
pidgemonkey is on a distinguished road
check for a good ground. If the ground is good buy a NEW socket. That should solve your problem.
Old Dec 17, 2009 | 02:21 PM
Eff10's Avatar
Eff10 is on a distinguished road
I have that EXACT same problem. The bulbs burn out in a couple weeks tops. The socket looks burnt to me so I'm pretty sure that's my problem but when I went to buy one they said it was on special order so I'm still waiting. It's just the right rear. I have not had this problem with any other lights. Funny thing is, when the brake switch and the blinker fuse/relay (not sure what its called) under the dash were both broken, the brake lights were stuck on and the light worked until I fixed those two things and now it's broken again. I also got pulled over for the messed up light which is frustrating because I'm actively trying to fix it. But yes, there is someone out there with your problem if that helps. Let me know if it is indeed the socket or something else.
Old Dec 17, 2009 | 09:55 PM
well for me it ended up being a bad bulb. last year when I had the problem I put in a new bulb, then when I replaced the socket, I used another socket and bulb. Now when I put the bulb back in,it caused problems. so now that bulb is thrown out and I have a brand new one in. I do however now have 2 used but working sockets, the new one that I installed game from Advanced Auto Parts, but Autozone and Pepboys both stock it also.
jasondis
Apr 5, 2014 04:54 PM
f-ten
Jan 8, 2010 07:45 PM
ta3ff
Oct 14, 2009 05:07 PM
eknox327
18
Jun 29, 2009 02:38 AM
Jimonawing
Nov 16, 2007 02:38 AM
