rough idleing
Old 06-02-2005, 03:57 PM
blazergirl15's Avatar
blazergirl15 is an unknown quantity at this point
Default rough idleing
i have been having problem after problem w/ my car...now when i turn it out it sound like a diesel truck and runs really rough when idleing...does anyone know what this could be? i was thinkin it was my EGR valve b/c ive had trouble w/ it before...but when that happened the car died and now its not so i have no clue.
Old 06-02-2005, 04:20 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
Default RE: rough idleing
It's possible that it's still EGR valve. Before you replace it again, if that's the problem, I would suggest getting one of those screens first, because a lot of the time the valve is just dirty, and if you get a screen for like $30, it's way cheaper than a new EGR valve that is still fine but just needs to be cleaned. It might have a crack somewhere in the manifold too...mine's like that right now and it sound similar to what yours seems to be sounding like. Is it auto or standard? If it's auto and it's shifting kinda strange as well, you might need to change your tranny fluid.
Old 06-02-2005, 05:31 PM
i do have a screen over it now.....my blazer also hesitates when i accelerate real badly...could that also be from the EGR valve gettin dirty?
Old 06-03-2005, 07:03 AM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
it could be as simple as a tune up. fouled plugs would have the same effect. how amny miles are on it?
Old 06-03-2005, 09:50 AM
m00nwater's Avatar
Ya, that's true. You might need to put some new plugs and wires in. I always think big at first, but zero's probably right that it's as simple as a tune up.
Old 06-03-2005, 10:18 PM
it has 193333 miles on it.....my dad is thinkin its the plugs too...hope he's right!
Old 06-04-2005, 01:28 AM
blazin97's Avatar
blazin97 is on a distinguished road
yah it sounds like you need a tune-up. If that dont work then you can always go to the bigger stuff like the EGR valve and so on.
Old 06-04-2005, 01:50 PM
well it wasnt the plugs....the wires...or the EGR valve....any idea of what it could be now?
Old 06-05-2005, 11:49 PM
zero psi's Avatar
Retired Admin
im not sure what year your truck is, but if it has a MAF sensor, try unplugging the wires from it. if it smoothes out the idle a little bit then you need a new sensor. but it may not have one. it could also be a vacum leak. do you hear a hissing at all? try squirting a little carb cleaner around the intake manifold and vacum lines. if the idle changes, then you got a vacum leak. do you have a check engine light on?
Old 06-06-2005, 12:38 AM
well it's fixed...my dad took the fuel filter off and blew air threw it and he put it back on and it ran fine....thinking maybe something was in there blocking it or it had water inside maybe?
Quick Reply: rough idleing
