Running rough at idle speed
Old Jul 14, 2005 | 11:37 AM
DED's Avatar
DED
DED is an unknown quantity at this point
Default Running rough at idle speed
I have a 94 s10 Blazer. It is a 4.3 with CPI. Recently it started running rough at idle speed. I t started out of no where. It was fine then I was going down the road at about 45mph and it felt like it was skipping, when I got to the light it was running extremly rough(almost choking itself out). The check engine light came on and it started to heat up. It has not been heating up since then but it still is running rough. I did plugs, wires, cap, and rotor and it is not any better. I thought the cat was plugged so I took that off. It is still no better. Does anyone have any suggestions at all? Please help.
Old Jul 14, 2005 | 05:25 PM
azblazer89's Avatar
azblazer89 is an unknown quantity at this point
Default RE: Running rough at idle speed
I just got a 94 Blazer - with the same engine as yours - from my aunt. She had a similar problem where the "Service Engine Soon" light came on and the engine ran rough. Apparently it was the EGR valve, which needed to be cleaned or replaced. Don't know if that's what your problem is, but it might be worth checking out.
Old Jul 14, 2005 | 10:52 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
get your computer scanned at auto zone and that would start you off in the right direction. but it does sound like an egr problem.
Old Jul 15, 2005 | 02:46 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Clean the tube that connects the EGR valve to the manifold out with carb cleaner, you may have excessive carbon build up
Also check the fuel filter, and run some STP Gas Treatment through the fuel system, you may have water in the lines or something
blazerguy22
Nov 14, 2013 11:50 PM
justinh4578
103
Nov 4, 2011 05:12 AM
nhguy261
Dec 30, 2010 01:41 PM
jannes_z-28
Sep 4, 2009 11:58 PM
wildboar
May 29, 2006 04:35 AM
