Runs 20 min then cuts out, HELP!!!
Old Dec 17, 2012 | 05:58 PM
amrcnmade's Avatar
amrcnmade is on a distinguished road
Default Runs 20 min then cuts out, HELP!!!
91 Blazer, EFI, runs for about 20 and then quits. sometimes it starts right up again. Sometimes not. Have replaced the MAP sensor, Ignition coil, and the Ignition Module. Suspected fuel filter but if it was clogged would not fire right up again sometimes. Suggestions please!!??
Old Dec 17, 2012 | 06:06 PM
Twip's Avatar
just change the fuel filter. if you are having doubts about it. they are only a few bucks and quick to change. a couple of wrenches and a catch pan. just dont let the gas get in your eyes.....it hurts reallll bad. it could be a fuel pump acting up too. it could be talkin to you.
Old Dec 17, 2012 | 06:10 PM
chris015's Avatar
gas in eyes hurt,but not like brake fluids.
id change the pump. they are bad about going out. only go with ac delco or you'll be back in it.
Old Dec 18, 2012 | 06:53 PM
amrcnmade's Avatar
So I replaced the filter and the pump today. Still no joy. Im out of ideas? Where should I look next?
Old Dec 19, 2012 | 04:19 PM
Twip's Avatar
how about a good ol' fashioned tune up? plugs, wires, cap and rotor... there can only be so much that is going to keep it from running.
or your distributor could be going out. does it surge or idle waaay up like around 2500 or 3000?
barnesto
31
Jun 11, 2014 07:12 PM
fixer34
Mar 16, 2014 10:45 AM
blazer83
Sep 30, 2012 04:15 PM
sp4freel
Oct 21, 2009 07:20 AM
ctberry78
Mar 24, 2009 08:33 AM
