s10 blazer 1991 won't start anymore
Old Dec 10, 2020 | 03:27 PM
vincent1972's Avatar
vincent1972 is on a distinguished road
Default s10 blazer 1991 won't start anymore
hello,
my s10 blazer 4.3 TBI 1991 won't start anymore after a stand still for 3 months.
the starter crancks but the engine doesn't run.
the battery is new.
he used to run like a charme but now after repair the rear wheel bearings and recover from my back injury. is this my new problem
what do you think what the problem is? bad fuel (here in belgium it is e5 5%ethanol)and bad/clogged fuel pump if i turn the key to on, i hear nothing but i don't know if you hear the pump if you turn the key to the on position (this model
Old Dec 10, 2020 | 05:42 PM
Should hear the pump coming from infront of rear drivers wheel, if its a left hand driver, not sure if its the same on a RHD.
there is also a valve by the distributor to put a fuel pressure testor to see if you have enough pressure if the pump does work...
Old Dec 11, 2020 | 07:15 AM
after crawling underneath the car i now hear the pump if the key is on the on position
Old Dec 11, 2020 | 03:00 PM
Do you have fuel to your engine? You can check the valve under the hood, or remove the filter.
But I suggest just using a fuel pressure gauge under the hood to start with, it will save you a bunch of running around for nothing
Old Dec 11, 2020 | 03:07 PM
that i haven't tested yet that i have fuel at the engine.
but i don't have a fuel pressure gauge, i have to look for one to order
where is that valve located , do you have a pcture maybe?
Old Dec 12, 2020 | 06:50 AM
I'm having a hard time finding a pic of the first gens.
I own a 99 so I think its a different location.
I did read that the smaller engines in the s10 did not have one(not the 4.3l v6).
Old Dec 15, 2020 | 03:20 AM
91 may not have a Shrader valve to check fuel pressure at the TBI.
Simplest method is to remove the air filter and have somebody crank the engine. You can see the injectors spray fuel down the TBI.
WARNING: No smoking, no open lights, fire etc. you are dealing with a fine spray of gasoline. Have fire fighting equipment ready at hand and a fire-proof blanket to extinguish anything if the engine for whatever reason fires back!
Maximum 3 - 4 seconds cranking. Try 1 time for a maximum of 2 times. No spray = no fuel.
Video at time 16:00 shows starting the engine with the air filter off and shows what the spray of fuel usually looks like at idle. A penlight is useful as a light source. Again be weary of the ignitable fuel.
The guy has added an aftermarket T-piece into the feed line for the fuel pressure gauge. And at first it leaks... the reason to be assertive of the dangers of gasoline under pressure.
Old Dec 15, 2020 | 04:34 AM
Thanks i'm gonna chack this
Soldat251
Jan 28, 2024 10:36 AM
wendelldevereux
Jan 7, 2016 09:37 PM
daveiam
Jan 31, 2011 10:22 AM
markmeister
Dec 2, 2010 09:53 PM
dcblazer
Nov 20, 2006 10:22 AM
