Shifter Lever broke
Old Jun 15, 2009 | 02:50 PM
tprouty's Avatar
tprouty is an unknown quantity at this point
Default Shifter Lever broke
So the shifter lever is broken on the steering column, and I dont really want to buy a new one... Does anyone know of a creative way I can repair this?
It works. It just comes out of where its suppose to be secured. There are no issues shifting. I would leave it but when i hit it or go over a bump it pops out and goes on the floor.
Someone tried to tack weld = fail
"Mighty Putty" = fail
I'm open to try anything that you think will work.
Old Jun 15, 2009 | 04:45 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
i beleive there is a pin type thing that holds the shift lever in place so you could just buy a new pin to hold it in place or rig up your own pin to keep the lever in place.
Old Jun 15, 2009 | 05:23 PM
rriddle3's Avatar
You know, that's the weirdest looking Blazer I have ever seen.
Old Jun 15, 2009 | 10:50 PM
What has failed here? If it is the type of failures I have seen, the collar on the steering column actually breaks out where the pin is held in place. If this is what has happened, the only real way to fix it without really cobbing something up is to replace it. You would probably be surprised at what a junkyard column would cost.
Old Jun 16, 2009 | 07:09 AM
tprouty's Avatar
Thats exactly what happened. I looked on Ebay and all I could only find would be 100+
I'll check junk yards
Thanks
Old Sep 17, 2009 | 10:41 AM
tprouty's Avatar
bring up my old thread, will this fix my issue?
http://www.autozone.com/autozone/cat...Name=Lockworks
Old Sep 17, 2009 | 04:22 PM
old skool luvr's Avatar
i don't know what the wreckers around you charge, but i can p/u a coluum for $50, and that's Canadian, hahahaha! did the coluum break off, or did the bottom of the shifter arm?
Old Sep 18, 2009 | 06:42 AM
tprouty's Avatar
The part where the pin goes to hold it in, the plastic on the column
Old Sep 18, 2009 | 10:26 AM
yeah, i though it would be the collar (i've only ever seen one lever actually break before-that'd be me ). check your wreckers, they should be easy to find one.
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
Blazinjay04420
Jan 14, 2010 09:28 PM
terry2707
Jan 10, 2010 06:42 PM
rbcar1
Dec 13, 2009 10:20 AM
