Slow Start
Old Feb 26, 2007 | 02:20 PM
throwedback's Avatar
throwedback is an unknown quantity at this point
Default Slow Start
i have a 93 blazer with the 4.3 L. fueli injected when i go out to my truck and try to start it , it will crank for more than usual then start after about of 3 seconds of crank (not usual) once i turn it off and start again it will fire up immediatley and ideas or know anyone who would know, jon wichita,ks
Old Feb 26, 2007 | 09:48 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: Slow Start
Put a fuel pressure gauge on it, then start it, and shut it off. Watch the gauge and see how much pressure you lose, and how fast, you will need to watch the gauge for up to 10-15 min. If the gauge drops to zero, or close to it, you probably have a fuel leak from either the nit kit, or the fuel pressure regulator. If the gauge does not drop more than 10-20 psi it is okay, and the problem is elsewhere. What happens is you loose fuel pressure then it takes a while to rebuild the fuel pressure when you go to start the engine.Korey
zashwood
Dec 30, 2010 07:51 PM
95Jimmy
Sep 1, 2009 09:05 PM
terry s
Jun 29, 2009 11:15 PM
503blazerluv
Apr 30, 2009 02:56 PM
Jimmysls98
Feb 28, 2007 10:40 PM
