smoke from a/c control?
Is your carpet wet on the passenger side of the transmission tunnel? If it is, then your problem is most likely your heater core.
If not, it could still be other things... Does it smell like burnt electronics?
The heater core should not be causing any burning smells, the worst you could get would be plastic that fell in there perhaps melting off..
The smoke actually comes out of the control unit, NOT the vents?
I would second swartlkk's opinion that its a resistor pack.
Yes, it comes out of the control unit and it smokes no matter if i put it on a/c, heater, or vent. I'm thinking it could be that because when I adjust the speed from low-high it feels the same. If it is the resistor pack is this all I need?
http://www.oreillyauto.com/site/c/de...2627&ppt=C0039
and is it very hard to replace?
There are a few options .. Looking on autozone's part lists..
I would pull the control section out, and see what smells, it may just be the fan switch apparently.
The main blower motor control would most likely be by the motor itself (sorry i havn't done anything with this on my blazer, but I had one go out on a 93 taurus a while back .. )
