Spark + Fuel = Nothing??
Old Jul 11, 2011 | 03:02 AM
ohsofly's Avatar
You gotta check the fuel pressure for a leak inside man... Its prolly gona end up being a leaking spider unit inside, its pretty common now that the trucks are 16+ years old... The only way to tell is to test the fuel pressure.
Old Jul 11, 2011 | 09:34 PM
chevynap79's Avatar
chevynap79 is on a distinguished road
All righty, I finally got a fuel pressure gauge put on it. When I turned the key, it jumped to 40-45 psi. After a few more times, it would go to 40 and then jump all around up to 60 and back before it fell to 0. While running, it stayed at between 55-60. I drove it around again after adjusting the timing and it still missed out, but I think that's because of a plug wire that's spewing sparks out of it.(It was a 'save my butt' wire, I just haven't had the money to buy new ones yet) So I've got pressure, yet it won't start unless I put a small amount of fuel in the trottle body. Is that the symptoms with the spider units? At over $250, I really hope not! If it is, is there a more reliable replacement for them? I know it's a factory flub, but are there units that are better than another? And I haven't checked the regulator, because I don't know where it is. I feel I'm sooo close to the answer...
Old Jul 12, 2011 | 01:36 AM
jigger's Avatar
jigger is on a distinguished road
Did you re-connect the vac lines that were off? Extra air (un-metered) and your iffy fuel pressure could make it want to be primed before it will start.
If you can't find where they go then plug them for now and make sure there are no open vac ports to the plenum/intake manifold.
Old Jul 12, 2011 | 03:04 PM
chevynap79's Avatar
As far as I know all the vacuum lines are connected. I don't hear the massive sucking sound when its running. I'm not sure if they're where they were before though. They had all been removed when we changed the ignition module and pick up coil. I don't know if it'll make a difference how they're hooked up as long as they're hooked to something. It gave me false hope because it did actually start once on its own. The next time I tried it, it just turned over and over.
Old Jul 12, 2011 | 05:47 PM
chevynap79's Avatar
So this thing has started on its own three out of 15 times. When it starts, it does like normal. The other times it just cranks. If I prime it, it starts fine each time. Would this be a computer problem maybe? I'm runing out of hope!
Old Jul 12, 2011 | 05:52 PM
40-45psi is NOT enough pressure for your motor. Minimum 55psi is required for proper operation (both starting & running) of your engine.
Old Jul 12, 2011 | 06:17 PM
chevynap79's Avatar
So it sounds like a tank to engine problem? Weak fuel pump, bad filter or regulator? Is there anything else I should check? I've got zero money to spend on guessing or I'd replace everything! Thanks for all the advice!
Old Jul 12, 2011 | 09:28 PM
chadillac85's Avatar
chadillac85 is on a distinguished road
sounds like a weak pump best to go with a ac delco pump it will last longer and save u the hassle of pulling the tank twice(learned from first vortec). good luck wish mine were as easy .
Old Jul 12, 2011 | 10:45 PM
chevynap79's Avatar
Thanks everyone! I guess as soon as I can come up with the money, I'll replace the fuel pump. And chadillac85, sorry you're problem's not an easy fix! Good luck to you too!
Old Jul 12, 2011 | 11:19 PM
rmitch's Avatar
rmitch is on a distinguished road
Before u buy any thing, be sure to take pump out and check the sock(filter) on the bottom of fuel pump to make sure it dosent have anything blocking it! While you got lines disconnected from tank,(also disconnect lines at TB) then take a air compressor and blow out lines real good! Finally reconnect everything and see how it does! You may just have some trash to slow down pressure! good luck
