speedometer doesnt work.ugh
Old Jun 30, 2009 | 10:44 PM
chris015's Avatar
Default speedometer doesnt work.ugh
Finnally found a obd-1 (or w/e its called) computer to check for codes. It says the speed sensor is bad. The speed thing attached to the ecm has already been replaced and didnt fix it(got it for free wooohoo)..I havent replaced the sensor on the tail of the transmission yet. I noticed when i turn the steering wheel the check gauges light flickers and i hear a buzzing etc. coming from somewhere behind the cluster. No idea where yet. Anyone had similiar problems? I bought the blazer this way thinking it would be a "easy" fix..ugh..
All the gauges work but the speedo.
91 s10 blazer 4.3 tbi
Old Jul 1, 2009 | 07:39 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
im pretty sure that the gear in the transmission is shot or the connector in the back of the cluster is worn or disconnected. if its an analog cluster. if its digital i have no clue.
Old Jul 2, 2009 | 06:40 PM
This truck will have an electronic VSS. I would remove the VSS, inspect it, clean it and the toothed ring inside the transmission tail housing. Reassemble and see if anything changed. If not, I would replace the VSS.
Outsydr
Dec 13, 2010 01:16 AM
in4lo
Dec 7, 2008 08:55 PM
NVANZEE
Jun 27, 2008 11:32 AM
stevenf
May 24, 2008 07:49 PM
idg4ever
Jan 22, 2007 07:41 PM
