Speedometer problem
i have an 86 s10 with the 2.8L. the other day i pushed the button to reset the trip meter and the speedometer and odometer stopped working the gas and the other gauges work though. I was wondering if anybody out there has run into this before and what could be wrong with it
I take it that the needle is sitting at 0 mph. some times the needle comes loose on the fit ( like the hands of a watch ) and drops to the bottom...if there's no pin at the rest position the needle will be lower than normal.
Seems to be a trend! (sigh)
My 94 is making noise now as if the speedo is about to let loose...but since it's a digital dash, I need to see if I can figure out how to even check if it's loose or not! Good luck with the repair!
If you have a digital dash there isn't any kind of cable like an old speedometer. Your speedometer runs off a Vehicle Speed Sensor (VSS) at the transmission (2 wheel drive) or the transfer case (4 wheel drive) to a VSS buffer located next to your computer. I'd check for some loose screws or maybe even a loose or broken light bulb. The dash really isn't that hard to pull. When you get it out you'll just see a big receptacle that the dash plugs into. I'd look elsewhere if one of the items mentioned above isn't the problem.
Thanks, Gimpy. I've actually had the dash out a couple of times, so I know the receptacle you're talking about. And thanks a bunch about the VSS! I had wondered about that but hadn't looked into it yet. So I guess I'll need to check everything else the next time I need to get into it. I hope that the next time will be when I replace the digital dash. I hate not having all that info at my fingertips! I haven't even had a fuel gauge for the past few years and have had to rely on NASCAR methods.....I reset my trip meter every time I get gas and top it off. As long as my MPG doesn't change (and I always check that too - yes, I'm a bit of a nerd concerning these things) I know that I can get about 250 miles per tank. So I start thinking about gas when I hit the 200 marker....I guess it's a good thing that I still have my speedo and odometer!
Oh! And the odometer comes and goes too for some reason! I'm sure that's also a loose connection because it comes back on if I bang on the dash. You gotta love the high tech methods of fixing things!
h84gotten
15
Aug 27, 2012 01:51 PM
gearyr
Oct 24, 2010 05:56 PM
