starter ?
Old Mar 29, 2007 | 10:29 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
Default starter ?
Well my starter blew out, i think.
It worked fine, then took more to crank it over, now the question is, if it clicks its the solenoid, but I noticed it has a starter relay, Im just not sure which one to replace.
thanks in advance.
Old Mar 30, 2007 | 11:40 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: starter ?
Usually 9 times out of 10 its the starter itself. so I'd start with that if it was me.
Old Mar 30, 2007 | 03:28 PM
Yeah, it is the starter for sure, but I noticed there was a starter relay too which I have no idea where it is at, the thing doesnt even click anymore, just dead silence.
I guess its a trip to autozone to get a junk starter since the other ones I usually use are over $250.
I appreciate the response dory.
Old Mar 30, 2007 | 07:45 PM
Zygoat's Avatar
Zygoat is an unknown quantity at this point
if it doesnt click then it is eaither the relay or the selonoid, that doesnt mean that the starter is not also broken. try the relay first, then its up to you becasue i think the selonid is part of the starter, although it can gernaly be replaced seperatly you might want to just get a new starter, your call.
Old Mar 30, 2007 | 11:48 PM
Where is the relay at? Im going to be wiring in a remote solenoid( think ford) instead of using the one on the starter, it always worked on my small blocks before dont see why a 4.3 would be any different.
It did click and if I smack it , it will click but after it sits for a day it doesnt even click. Im just glad its easy to get at.
Old Mar 30, 2007 | 11:55 PM
Zygoat's Avatar
what year make model?
Old Mar 31, 2007 | 12:14 AM
Zygoat's Avatar
my chiltion covers 94-04 i am going to assume you are in that groupe, acording to the chiltion there is no realay, furthermore they do not recomend replacing the selonoid seperate form the starter motor, although i am sure i can still be done. my advice is to pull the starter off and take it to an auto parts store they can check it, if its bad, and i think it is, then just buy a new one and put it in. if it is ok, tell us and well take it form there.
Old Mar 31, 2007 | 04:30 PM
Its a 92, I replaced it already, took a while due to the fact that you have to remove the front driveshaft, flexplate inspection cover, tranny lines and then you can get it down. Im going to toss out my Haynes manual and get a chiltons or a factory manual
Old Mar 31, 2007 | 05:26 PM
Zygoat's Avatar
what did you end up doing, is it working good now?
Old Apr 2, 2007 | 11:28 PM
I replaced it, works brand new now.
I am very discouraged with OTC manuals for these vehicles, they neglected to inform the reader that you have to drop the front driveshaft, a flexplate cover, move tranny lines AND somehow disconnect the wire at the starter WHILE its mounted on the vehicle.
It was a PITA but it was done.
jdmmario
Oct 25, 2014 06:25 PM
an240172
Nov 18, 2009 09:32 AM
Blazinmail
Mar 17, 2006 08:47 PM
blazergirl15
Aug 28, 2005 11:17 PM
blazin4eva
Feb 26, 2005 12:04 PM
