Starter noise
Old Dec 15, 2005 | 01:59 AM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default Starter noise
Ok, the past couple days I've noticed that when I try to start my truck, I hear the starter kick out, but that's it. It does it when I leave for work in the morning and when I leave work at night. Basically whenever it's been sitting for a while. I hear the starter kick out and whine, but the truck doesn't start.
I suppose it could be the starter, but I'm wondering if it could also be a flywheel problem. Never ran into this before. Usually the starter either kicks out or it doesn't. I've never had it kick out but not engage the flywheel.
Old Dec 15, 2005 | 08:10 AM
Default RE: Starter noise
How have you determined that it has kicked out the bendix? If you hear it whirl (spin), without engaging the flywheel, then it's probably the solenoid on the starter that kicks out the bendix. I know that on earlier GM starters, you could pull the solenoid off and clean it, but now-a-days you could probably just replace it for little $$$.
You must be able to get it started if you are getting to work. I'd bet it is a weak or sticky solenoid.
Old Dec 15, 2005 | 01:37 PM
Yeah it starts on the 2nd or 3rd try with no problem.
One of the mechanics at the AutoZone where I used to work says that older Chevys are known to do this. He's got a '95 Camaro and he said his does the same thing.
*Shrug* I'll check the solenoid out
Old Dec 15, 2005 | 01:42 PM
93LT's Avatar
93LT is an unknown quantity at this point
A lot of times when a GM solenoid goes bad, it starts to push the bendix out and then slams it back in, giving the sound that it kicked it out. Then it's just spinning, not engaging the flywheel/pressure plate ring gear.
Old Dec 15, 2005 | 02:05 PM
Hanr3's Avatar
Time for a lifetime starter replacement.
Old Dec 15, 2005 | 09:23 PM
Beware of store brand lifetime warranty starters! I spent 2 hours and 3 trips to the store to put a starter in my neighbors firebird. The 2 extra trips to the store were to get extra shim packs. Over an 1/8th of an inch in shims to get the check block in!!! Yikes. The rebuilt starters often do not maintain the same alignment or even close.
Old Dec 16, 2005 | 12:18 AM
93LT's Avatar
I agree, don't skimp on a starter. I try to go AC Delco on remplacement parts like starters, alternators, etc., unless I know the rebuild brand to be a good quality one.
jdmmario
Oct 25, 2014 06:25 PM
peterbilt64
Dec 22, 2010 10:20 AM
offskooring
Jul 31, 2009 07:59 PM
joey
Feb 15, 2007 08:08 AM
blazergirl15
Aug 28, 2005 11:17 PM
