steering column swap to tilt?
Old Dec 22, 2006 | 06:39 AM
kakn's Avatar
kakn is an unknown quantity at this point
Default steering column swap to tilt?
my blazer has a non tilt column in it now and i'd like to add a tilt. i've done some research and seen a few on e bay but i've had mixed reviews. the column i have now is standard and does not have cruise control. ive been told that there are different connections on a tilt column vs. a non tilt. im 6'2 290 and have a hard time getting in and out. my legs rub. i've thought about replacing the steering wheel with a smaller one but id really like to have the tilt. i've tried to figure out if there are any actuall physical differences between the 2 columns with no luck. i dont know if maybe the extra connector is for the cruise? if i dont have cruise will it matter?
has any one swapped one or have any info that might help?
Old Dec 23, 2006 | 02:21 AM
Chevy Lover's Avatar
Default RE: steering column swap to tilt?
You should be able to find a tilt column for your year Blazer. Just find one with the same options that you have and the connectors should match up.
I put a tilt in my '85 that has a cruise and pulse wiper switch on it. I don't have cruise or pulse on the truck, so I have 2 loose connectors and my tilt steering column.
JBlaze2K
Nov 23, 2013 11:26 AM
maepis
Dec 21, 2011 06:10 PM
Big Ace
Jun 21, 2011 11:37 AM
Breener
Jul 24, 2009 07:40 AM
ghostrider2k
Feb 7, 2007 12:09 AM
