Tilt steering collum to loose to drive
Old Jun 6, 2011 | 07:39 PM
Big Ace's Avatar
Big Ace is on a distinguished road
Cool Tilt steering collum to loose to drive
88 Chevy K-5 Blazer has tilt steering and felt like it broke one knight. Now it is so loose when you turn the collum turns so much the engine shuts off. Any suggestion on how to fix myself? Thanks
Old Jun 21, 2011 | 04:39 AM
smg614's Avatar
smg614 is on a distinguished road
You have to pull the steering wheel off and tighten or replace the 3 bolts that are in there. I've had that problem and put some blue loctite on the bolts. No problems since. Hope this helps.
Old Jun 21, 2011 | 08:51 AM
chris015's Avatar
They always tend to come loose. My old blazer was bad.
Old Jun 21, 2011 | 11:37 AM
A search for "loose+tilt+column" turned up the following reply:
Originally Posted by mr.vls
Do a google search on GM tilt column and you will find a few good write ups. I had the same issue and thought about tackling this job myself but I stopped by my idependent shop and they were really familiar with the symptom and repair. Basicly, they take the column apart to get at the mounting bolts remove them add locktight and reassemble. They charged me an hours worth of labor. My column is nice and tight now.
Below is one of the links that gives the repair procedure.
Tilt Steering Fix
Not the best link, but the google advice is sound. "GM Tilt Column Repair" or "GM Tilt Column Tightening" should get you more than enough info!
GodsMechanicalCreation
Nov 5, 2009 08:37 PM
Breener
Jul 24, 2009 07:40 AM
thevair65
May 16, 2007 07:34 PM
ghostrider2k
Feb 7, 2007 12:09 AM
kakn
Dec 23, 2006 02:21 AM
